How do y'all feel about running synthetic oil?
  • Yes it's worth the extra cost.
    Votes: 85 52.1%
  • No it's not worth the extra cost.
    Votes: 56 34.4%
  • What?! You mean these things need OIL????
    Votes: 22 13.5%
  • Total voters
    163
1 - 20 of 45 Posts
I just wanted to get everyone's thought on the extra cost of running synthetic oil.
Vinyl Sticker Guy
What kind of differences are you noticing with AMS-Oil? I'm going to change my oil soon, and I'm considering using AMS. Better fuel economy? Performance?
Lem
clean engine
yeah, the ams-oil really cleans out the engine. I think my truck runs smoother, sounds more smooth, everything. It is the greatest. I also used ams-oil tranny fluid when i rebuilt that.
In another vehicle I have, we have been running ams-oil in it since 40K miles, it is currently over 218k origional miles...everything origional and this is a 4cylinder, gasoline engine, runs like a champ! but the best part is to see the inside of the engine block, it literally looks BETTER than new. where as most engines of that use are totally black inside, this one is shiny as ever. I'll post a pic later, I have to take it still though.
The only negative thing about this kind of oil is the cost, but for the engine life it gives I think that it is worth it!
Thanks Turbo!
This thing has 58 views and only 3 votes? What's up with that? :p
whats the cost approximately for an amsoil change, do it yourself or pay someone, have friend of mine who has 218,000 miles on 99 psd and just changes his oil every 4-5000 miles with regular oil, still runs like a champ
If you drive a lot in Mexico, wouldn't it be better to use Oil of Olay?:rolleyes:
i dont use Synthetic Oil i dont think it is worth the extra money. I know guys with 250-300k on there trucks and never used it with out any problems.
I use Shell Rotella T 5W-40 Synthetic year round. In the winter helps cure the ROMPS. At Wally World $14.00 a gallon. I change the oil and filter every 5000 miles and send an oil sample to Blackstone for analysis. Keith
Cost for oil change by yourself and w/o new filter is right around $80.00 and changes due around 10K miles, or so.
Conservative and Proud
So it's basically about the same cost??! I've heard both sides, and as of yet, haven't made up my mind.:eek: ... which is why I voted, oil, these things need oil??????:D
Synthetics.........
Hey Rod,
I'm no petroleum specialist or anything, but I've talked to a few over the years about the differences, pro/cons, and what I've taken away from it is that if you are fairly faithful in changing your oil and filter, synthetics don't really offer anything beneficial enough to substantiate the extra cost. But...
if you're one of those who is a little less mindful and usually goes over several k's before changing, then synthetics are probably a good option. Basically they don't break down as fast, but they still collect just as much crap, even if they don't look as dirty.
RLTW!
Discussion Starter #14
Thanks Ranger - this has really been an interesting poll. I would have thought synth hands down but what you mentioned is probably the reason it's so close. Great point though!
oil
the only reason to run syn. in my book would be if you do alot of driving. if you rack up 1k miles a week, it may be impractical to change the oil once a month, therefore making syn. the way to go.
for those of us who dont do the higway miles, reg. scheduled changes are a little easier to plan and change.
the extra cost of the syn is not worth it, unless you have money to burn.
Synthetics make up the difference in price with not having to be changed as often. Classic example. Most of you are changing every 3-5k, some more, but most there. Amsoil, when used with the Amsoil/Donaldson filters is on a 15k severe use, 25k non severe use interval. Thats 15qts every 15k or 25k miles, instead of 45 quarts every 15k or 75 quarts every 25k miles. less waste, less time, better engine protection. Also, most people when switching see better mileage (slightly) and a smoother running engine. These are the reasons I use it. I sell it because I use it and I believe in it.
My :twocents:
BUT, oil should not sit in a motor too long, and i agree with brian that if your not putting considerable milage on a truck, the oil needs to be changed to get condensation out regardless of hte oil quality...
Very true. Condensation is very bad for any motor and if it is not seeing the milage to heat it up and out of there then you are open to many issues.
Amsoil says you can go 1 year on an oil change without worrying about the it. I would say that if a person has a vehicle that is driven that little then they should look at the situation from the veiw of moisture in the area, how many heat cycles, ect. if you are driving it 3 days a week 10 miles each way, you are probobly getting it hot enought to get rid of the excessive water. If it sits for 2-3 weeks and then gets driven a few miles off and on, then maybe not. There its kinda the customers choice.
ive replace a few motors for condensation problems, and i would say anyone who doesnt put at least 15k a year on a motor IMHO wont benifit from sythetic because they shoudl be changin thier oil by time and not milage...just my opinion...the average guy can see gains with synthetic, but here is always the extrememe...the guy who wont benifit from something....
1 - 20 of 45 Posts
