1 - 1 of 1 Posts
Ok, I had a 06 F350 with 2 Ton front coils installed plus rear airbag...It was totaled.
I bought a 03 F250 and because I plow snow and the plow was set up for the old truck (push bar was welded) I need the truck to be 4 inches higher.
I was thinking about buying used F350 springs (code x) for the front and springs for the rear (code B) plus blocks and add-a-leaf kit to acheive the total height and capacity I had in the old truck.
Any reason this wouldn't work? I figure seeing as I have the cab off right now to do the heads now would be a perfect time to get the suspension done.
PS...I hung a 975# plow on the old one with NO sag, and need the same.
1 - 1 of 1 Posts
