1 - 9 of 9 Posts
I just recently had a 6" Rize lift professionally installed on my 2008 Ford F-250. I am running 37X13.50X20 tires. The front looks great. The rear is sagging about an 1 to 2 inches. Is this normal and what do I do to have it corrected. Also, it cost me a pretty penny to do this. Is there a cheap fix. Thanks for your input.
yes just get a block for the rear, and yes this is normal did you get the deaver rear springs with that kit or did you get blocks
I got the blocks installed for the original rear. That means I have to purchase bigger blocks and longer u bolts?
Rize offers and has a application chart for dealers that will enable them to adjust the rear for the correct stance..sounds like they didn't take advantage of this info. For a level truck the block # is 440-300-182 if you don't have the top overload spring and 440-300-192 if you do. I would ask them to fix this at N/C
Cary
Cool, Thanks for the info. I will get on that
The guys at Truckers World of Corpus Chrisi, TX. hooked me up with longer u bolts and they installed my original blocks with the new ones and the truck is now even and actually runs smoother than previous. Thanks Truckers World!:icon_ford:
stacking blocks :( my suggestion is save up for some 6" deaver springs and install it with your factory blocks.....the ride quality is amazing....
Any company that stack's blocks should not be in business! Idiots!
Cary
1 - 9 of 9 Posts
