1 - 15 of 15 Posts
· Registered
Ok audio pros need help tuning my sound system. It is what it is and I cant buy new stuff so Im going to work with what I got.
So what I got is a power akoustic BAMF 2600/2 amp for 2 shallow mount Audiobahn AMW120H (12" 4ohm dvc) I basically need to know the best way to wire these. right now the box is a Ford F-250/ F-350 Supercrew Cab 99-07 Dual BTS Subwoofer Box with dual wiring ports/split box.
so whats the best way to wire this setup? single voice channel, parallel 2 ohm load , drill a hole and connect the speakers and bridge the amp?
To many choices need guidance.
thanks
· Premium Member
I'd run them both individually to the amp, then bridge the amp and make it a 1 ohm stable load....I had two jbl gt 12s wired in 1 ohm stable on a 1000 watt amo in my Nissan altima and they hit HARD
· Premium Member
Mine were DVC SUBS also...but that shouldn't make that big of a difference.
· Registered
I was looking at different options like that but I dont think that will safely work with my setup. the amp is only 2 ohm stable. Ive been reading that if you only use one voice coil you loose much of the subs capablity.
· Registered
•BAMF Series 2600W Max 2-Channel Class AB Amplifier
•RMS Power Rating:
◦4 ohms: 450 watts x 2 chan.
◦2 ohms: 540 watts x 2 chan.
◦Bridged, 4 ohms: 1080 watts x 1 chan.
•Max power output: 2600 watts
•MOSFET power supply
•Wired remote bass level control included
•Power and Protection LED power indicators
•Adjustable Tuned Bass EQ (0-12 dB Bass Boost)
•PWM Circuitry
•Full Selectable Crossover (HI,Full,Low)
•Three-way protection circuit
•2-Ohm Stable stereo
•Tri-mode capable
•System Distress Indicator
•Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
•Platinum RCA level inputs
•Platinum screw terminals
•Variable high-pass filter (50-500 Hz, 24 dB/octave)
•Variable low-pass filter (30-250 Hz, 24 dB/octave)
•Subsonic Filter: 15-50 Hz
•Signal to Noise Ratio: 97 dB
•Frequency response: 10-30000 Hz
•Dimensions: 16-7/8"L x 8-1/4"W x 2-1/8"H
· Registered
Discussion Starter · #8 ·
Sweet!
You rock. Ive been using a different website and the setup they had produce really poor sound and I know the setup is cabale of much more. This looks like the ticket!
· Registered
Discussion Starter · #10 ·
yeah that looks way better than the silly shenigans I tried first! Ill get this wired up hopefully tomorrow and have a report. well that is if I get my new rca cables in, the ones from the wiring kit were bad
· Premium Member
That's exactly how I had mine wired up Eric,
· Registered
Discussion Starter · #12 ·
Do you have tight bass or loud bass? I have a small sealed box so Im not hoping for to much but thats why I got two instead of one
· Premium Member
Well, now I have two sealed boxes with 12s in them in my truck now. Before, I was into competition, so I had a bandpass box for two tens. I cut out 12 inch holes in the top of it and removed the inner boards that mounted the ten inch subs. I turned the 12s up side down and had them firing into the box and then the ports on the box made the bass explode. It was a third order bandpass box, with the trunk used as part of the box.
· Registered
Discussion Starter · #15 ·
thanks guys wired it up and much better! now I have to wait on my rca cables to give it a full run (bad factory cables)
1 - 15 of 15 Posts
