I have been smelling a strong fuel smell, it is strongest at driver side valve cover I have checked all fuel lines and can't find any leaks, Possible injector?? please help me narrow this down getting very frustrated
that is where the ccv is do you have a hole in the ccv hose or any parts of the ccv? also change your oil and see if that helps this is based on the ccv being right there and if you have a lil fuel in your oil you would smell it if there where holes in there
I have checked the coolant and the oil and no fuel smell to either oil only has about 2500 mil. on it is there a way to find out if an injector oring is leaking?
