So, this seems a little weird to me, as I dive into the diagnostic on my own truck (just what I want to do after spending all day diagnosing OTHER people's cars) I've noticed that when the key is off, opening the door is "supposed to" power down the systems inside the truck, such as radio, power windows, etc. But it doesn't.
So far in things I've observed and have a suspicion are all linked, are
Radio and power windows seem to have power at all times
my center console in the roof is inoperative and presents a B1342 electronic control unit malfunction code in the overhead trip computer module
I had a whole host of misc codes relating to loss of battery power, which I completely understand due to the batteries being discharged as a result of someone not knowing about this issue.
So far I've reached the theory that 1 of 3 possibilities has happened, in order of most likely to least in my experiences. #1 the fuse junction block under the steering wheel is faulty/corroded and shorting internally. 2. the accessory control circuit is somehow shorted out internally. or 3, the BCM is faulty. I suspect something is related to moisture, as I found the manuals in the glovebox to all be damaged in a way suggesting the truck has possibly seen rain inside at some point. I didn't see flooding evidence anywhere one would normally suspect, so I doubt it's a Hurricane Ian victim (I'm right near that area)
Any insights if someone has perhaps experienced this before? I can live with it for awhile while I research and pinpoint what I need to replace or repair, that's absolutely fine with me.
