Hello all,
Been quite a while since I posted anything here. My truck (details in signature) has been having a weird fuel pressure issue for the last 6 - 8 months. I've searched around and can't find anyone with similar symptoms.
After a cold soak (more than 24 hours after driving) my truck fires up just fine and shows almost exactly 60 PSI fuel pressure at idle. I let it run for about 15 minutes and pressure will still be in the 58.5 - 60 PSI range after oil temp >100F.
Driving at city speeds, the pressure hovers around 55-60.
However, after about 45 min at highway speeds something weird happens. Pressure slowly begins to drop. I lose about 1PSI every 5-10 min. After nearly an hour pressure bottoms out around 45 PSI. If I do a WOT run when it's this low, it will drop even lower (which I know is bad news).
If I pull over and and park, pressure will usually come back up to around 47-48PSI, but never go back up to the 60 PSI range when the engine was cold. I can shut down the engine, wait 5 minutes and re-start and the pressure is still in the 45-47 PSI range.
This would all be well and good if this problem happened every time... but, if I leave the truck for maybe 3 - 4 hours and then drive again, I have absolutely no problem. I can drive back home on the exact same route that takes the same amount of time and pressure will remain within 55 PSI - 60 PSI the whole way.
All other vitals of the truck are good. Fuel filters were changed about 4000 miles ago. There is no sign of a leak in the fuel system anywhere. Exhaust seems normal with no sign of fuel at the tailpipe.
I haven't done anything yet to fix it... wanted to get some ideas from the community here first. I do have an adjustable fuel pressure regulator on my bench ready to go in if needed. I'm hesitant to install it as my problem isn't consistent. This low fuel pressure issue only seems to happen intermittently... but when it does, the problem stays there until the truck has cooled for a while.
Maybe a bad O-ring internally somewhere? No sign of fuel in the oil (that I know of)... and my MPG hasn't changed much... Maybe the regulator is getting stuck?
Any ideas would be welcome. Thanks!
