Also keep in mind that after installing the HPOP, there's a good chance of air in the oil system, so it might take a while for the first start after that kind of job, it helps to have a battery charger hooked up while while doing so, so that ur not murdering your batteries, and a scan tool so that u can watch if you're building up ICP pressure while cranking....I had that problem once and seemed like I was going to burn out my starter, so make sure you don't crank for too long neither, but it eventually fired up and I held the RPMs high for a while, took it on a fairly long test drive....afterwards, it fired up within a few seconds
Sent from my PG86100 using AutoGuide App
