I managed to fix my sticking horn contact on my 2000 SuperDuty - air bags are steep$ and if you try a used one, you don't don't know how long the horn contact is going to work anyway. You can't buy the horn contact separate from Ford, but it does have a TRW part# on it.
Even if your horns are bad and don't sound, a sticking horn contact pulls in the horn relay and will make your batteries go dead in about a week. And if the horn relay is bad or you pull it out, then your cruise will not work.
I put in a new horn relay and checked the horn fuse.....and put in new horns, it wasn't until I put in the horns that I even knew the contact was bad....and that the stuck horn contact was the reason my batteries were going dead. I needed the horns anyway - the old ones would not sound with a separate power source.
Main issue for me was the fact that the cruise wouldn't work when the horn button was stuck (before I replaced the horns, so no noise). The stuck horn button caused the horn relay to heat up and go bad and the cruise would not work with a bad horn relay in there. If your horns are bad, which is common, you probably won't know the contactor is stuck, but it will prevent your cruise from working.
The ironic thing about it that a horn that doesn't work causes people (including me) to push the horn button even harder.....which is what causes the horn contactor to fail.....thereby adding yet another issue causing the horn to not work instead of getting the horn to sound......kind of funny when you think about it - now you not only probably need new horns but the horn contactor is screwed up too.
On to the contact fix:
First, don't remove the airbag from the steering wheel until after you:
1. Disconnect both batteries.
2. Wait about 10 minutes.
3. Pump the brakes a few times - this gets rid of any residual voltage.
Also do not ever use any kind of meter on the airbag. Once you get the horn contact away from the airbag then you can meter the horn contact if you want to but don't do it when it is still in the airbag assembly - you could mix up on the wires and think you are metering the horn wire but you are doing the airbag discharge wires by mistake - NOT GOOD since it may go off !
To remove the airbag, remove the plastic screw access caps (2 total) on the back side of the steering wheel and then take out the two 8mm headed bolts. Lean the airbag out some from the steering wheel and you will see there are 2 wiring plugs to disconnect, the red one by the 2 screws is the horn, the other goes to the airbag. Study the plugs and be careful with your disconnect method so you don't break them.
Here is the back side of the airbag. Remove the 2 screws at the top of the pic, pry the bottom side of the clip U tangs on each side apart a little and the clip will come off and you can open the cover to expose the horn contactor which is 2 films of copper laminated to 2 films of plastic which are adhesived together around the edges. There is a pic of the U clip in the last post below.
