I have a 2000 SD, 7.3 with a bad rear end. My sterling axle code is 406H with an open diff. The best I can find on the net is 100-200 serial number axles are for gassers and the 400 series are for diesels. Of course, all the local junk yard axles are $100 to $300 for the 100 to early 400 series. Then my 406H is $500. I struggle to believe there are 30 differences in all the series and why would the 406H appear to be an outcast? Any information would be great. Thank You Very Much!!
Whats bad in the rear end?
the gears have slowly been going bad and with the iron in the lube, it is time for a total overhaul....replacement
