21 - 28 of 28 Posts
· Administrator
not sure if they will have plugs or just plastic caps, I would call and ask them and they might throw them in.
Either way they are standard fittings, so you just screw in the tap and cap it or use a plug.
I kept these and two spare lines in the truck incase I ever had an issue because if you lose a line you lose brakes and steering.
· Registered
Discussion Starter · #22 ·
Appreciate ya Heavy_GD, Blue Top box comes with fittings pre installed to block off ports. This is good info for anyone who comes across this post. Thanks for all your help.
· Premium Member
2005 Ford F-250 Lariat Crew Cab FX4
You will need a 1-13/16" socket and a decent pitman arm removal tool. Out of the local parts stores, Autozone was the only one that had a tool that would barely fit. Hopefully that saves you some time.
· Registered
Discussion Starter · #27 ·
Well BlueTop Steering Gear box is installed an I must say I’m in control again. It’s not 100% but I must say it’s pretty close. Little to no play in steering now. I am very pleased with going with BlueTop. Im still thinking about steering assist just because of the size of the tires. I don’t want to over work this steering box. Take care fellas
· Premium Member
Glad you got it done. If you still have play, it must be in some of the linkage that's worn (tie rod ends, ball joints, etc.) Mine's as tight as a straight man's buttox in prison
21 - 28 of 28 Posts
