1 - 2 of 2 Posts
I have a 2003 F250 6.0l crew cab 4x4 that I'm having steering box rebuilt and replacing all linkages. So far my research on the internet trying to locate torque specs for everything has been all over the place. As of now I have steering sector shaft to pitman arm nut( spline side) 200 ft lbs. Pitman arm to drag link castle nut 67 ft lbs. Tie rod to steering knuckle castle nuts 67 ft lbs. My question is what is the torque value of the drag link to tie rod castle nut? It appears to be larger than the other 3 castle nuts so I thought it may require a larger torque value. Can anyone advise me on that and does all the other info appear correct? Thanks
1 - 2 of 2 Posts
