1 - 20 of 43 Posts
What's the reason for some trucks having them stock and some do not? Certain package, etc...
Mine is an xlt 4x4 and as far as I know it didn't come with one.
War is the answer!
As far as I know all fx4's came with them.
Sent from my SPH-L710 using AutoGuide.Com Free App
My 04 F350 SRW FX4 came with one.
War is the answer!
I have an FX4 without one.
Are you the original owner? I'm pretty sure they came factory with it....
I say that but can only be sure of the 04 F350.
I am not the original owner, I do not see any evidence of a stabilizer either. Could it be a 3/4 ton vs 1 ton thing?
My 06 3/4 ton came with one factory, its an FX4
Fathers 04 1 ton FX4 came with one, and my grandfathers 05 3/4 ton FX4 came with one and he bought new from the factory.
My '03 FX4 came with one.
Sent from my DROID RAZR using AutoGuide App
I have seen other 6L's on the road without them too.
Every 4th one on the line didn't get one????
Administrator
I imagine you know where they mount ? way up on the frame /steering linkage ? out of site on most lower trucks
it should be easy to tell if one was ever bolted in there ?
good thing is Rancho makes a factory replacement
my o6 FX4 250 KR had one
Discussion Starter #12
Yeah....I've looked over the area quite well when I did my level kit for worn front end parts and such and didn't see any evidence of a bracket installed or anything.
Administrator
does your steering linkage have a hole in it just down from the pitman arm?
I do recall when I bought My rancho they had 2 kits one for a factory replacment and 1 for a truck that never had one ?
the frame OEM mount is a drop bracket on the pass side of the engine cradle
I don't know how bad you want one but I really like the top gunz dual setup I have
Discussion Starter #16
Yeah, I have an '05 with the camper package....so not the heaviest spring package, but not the softest either.
Yeah, me too.
If you get one try the kyb, I have had good luck with them lasting on my excursion and 04 fx4, they are actually Dampeners, not stabilizers, and they do reduce vibration and kickback from the wheels, and can change the frequency of an ocilation, stoping death wobble, but they are a bandaid. they do not cure worn parts or poor alignment that caused the wobble in the first place. If your wheel/tire package is heavier, larger, and less round than oem you should have a stouter dampener(s) just like you should have upgraded shocks with a lift and tires/wheels.
My 04 FX4 350 has it stock.............
1 - 20 of 43 Posts
