2006 F-350 6.0L PSD 4x4 SRW Crew Cab long box with about 130K on it.
It all started with an oil leak coming from the top of the trans. on the back side of othe engine. Long story short... I was driving home from work when at a red light it shut down, cranck/no start. Looked under the truck and it pissed a S#!% ton of oil out. Had truck, towed home. After further inspection I find a large crack in the rear engine cover, just above the bell housing. I take a photo of the crack and take it to the 'steal'ership to get a part number and some advice. The tech said it looked like somebody was prying on it, and that it was going to be a pain in the *** to work on. THANKS. They put together a part list for me:
Quantity FORD Part Number Description Price NET
1 3C3Z-6A642-CA Oil Cooler $ 420.48
2 3C3Z-9439-AA Intake Manifold Gasket $ 38.10
1 3C3Z-9433-AB Gasket Kit $ 97.18
1 5C3Z-9F452-ARM EGR Valve $ 253.85
1 EGR Core $ 30.00
1 3C3Z-6G091-A Cover - Rear $ 380.56
1 3C3Z-6619-EA Gasket $ 22.68
Subtotal: $ 1,242.85
Tax $ 72.77
PAY THIS AMOUNT: $ 1,315.62
I found got all this same part numbers for like $890 from a dealer on ebay. Anyway, I'm into my tear down. I've got the tranny and the rear cover out. I see that (what I now know is the) STC fitting has failed and rubbed, bumped, and smashed through the rear cover. I'm learning so much about the 6.0 as I get deeper into this So I need to order one of those redesigned STC fitting. Today I did the top side and got all the way down to both the oil cooler cover and the High Pressure Oil Pump (HPOP). So at this point the intake manifold is out. Thats where I am as of tonight. During the tear down I found the last 'Ahole' to work on it lost two turbo compressor bolts and the o-ring had popped out where the bolts were missing. I found one of them, but there sure is a lot of grease all up on my engine. Anyway, I guess I'll have to take that apart and put a new seal in. I figure while I am in this deep I will pull the valve covers and check the Dummy Plugs. I know they updated them and I want to make sure I have the new ones. I'm not stuck or anything, but I was wondering if anybody had any words of advice, tips, comments, concerns, anything really. Especially on how to properly prime the systems would be awesome. I took a lot of photos during the tear down too, but its too late to download them and post them. I'm gonna be back at it tomorrow morning, I'm trying to get this done as fast as I can but I want to do it right if I'm gonna be in this deep.
Any input is greatly appreciated, thanks in advance
1 EGR Core $ 30.00
Tax $ 72.77
