My 05 f250 6.0 will start just fine when it is cold after the motor reaches normal operating temp. it will not start. let it cool down or use starting fluid and it will start just fine. I have changed the fuel filters, changed the oil and filter, used injector cleaner in a full tank of fuel. Once it is started there is no power lose runs great. Any Ideas?
Im no tech just a forum junky but from what I've read that could be the hpop. I'm sure a tech will be around shortly to give you some more input.
sounds like a leak in the high pressure oil system, most commonly the snap to connect bracket on the back of the HPOP.....thats relatively common on 05's
