Another issue... No surprise there. ts not wanting to start. I have good battery power it sounds fine starting, just doesn't want to start. I don't know if it's the glow plugs or something else. I can't don't know how I would go about testing and trying to figure out how to go about it. I don't know if it is a fuel issue. Any help would be amazing.
Old School
What are you using to measure fuel pressure?
You have to check ICP, IPR, FICM SYNC and FICM VOLTS for starters.
Didn't get to check anything really today, but the FICM Ignition voltage was at 11.50 to 12.50. And it actually kicked over today which i was really surprised cause it hasn't wanted to in almost a week. It is a lot colder today then it has been I think the high was like 75. I don't know if the heat has anything to do with it not starting. Another thing, I got a egr code for min. max issue and I checked the valve it looked fine. I don't know what would be wrong.
Well, I had oil pressure when it isn't starting before. Today after a shot die to get a whole in downpipe fixed, no oil pressure and it wont start again. I think the pump went out.
