Im having a no crank issue I may be chasing a ghost. Starter works I can jump it from passenger side fender yellow/blue wire. But get nothing from the key. I've checked all fuses are good. tested all relays are good. On the starter relay the 86 pin is 12volts the 30 pin is 12 volts. I tested the 87 pin wire is good all the way to starter. But.. im getting nothing on the 85 pin I can't get ground in any position of the key. My question is where does the 85 pin go to?
(2004 F250 6.0 lariat 4x4 extended cab)
