1 - 13 of 13 Posts
I have some corroded brake lines on my 2006 6.0. Does anyone have any experience replacing them with stainless brake lines? If so where do you get them?
There are a few places to get them, now including Dorman.
Check ClassicTube, SSTubes, as well as eBay, Amazon .....
I used sstubes on my excursion and was very pleased. Had a burr in one end of the rear line and they overnighted a replacement. No matter who you go with I would inspect all of the flares and spray some brake clean through then followed with dry air (I used nitrogen) through as well. Good luck!
Thank you very much for the help I really appreciate it!
I got the Russell lines for both of my Excursions from Summitt. Night and day difference in pedal feel for sure!
The Russell lines he is talking about are the hoses. I've used Classic Tubes when restoring '65-66 Mustangs and Shelbys. They were excellent. As David said, inspect the flares with any source.
Thanks for the clarification. I've never used stainless lines and hoses before so this is all new to me. I really appreciate all the help!
The other thing you can do is make up the lines with Nicopp, doing the flaring yourself. That is a little bit of an art though, especially with some of the tools out there today.
You can get pre-made and un-bent brake lines at many parts stores. Then all you have to do is bend them yourself. Tool for that isn't to expensive.
Discussion Starter #13
Thank you for the heads up. I actually already finished the job. I bought through SS lines and they did give me a discount. The lines fit perfectly and came pretty fast as well.
1 - 13 of 13 Posts
