1 - 5 of 5 Posts
ok. Im planning a set of rosewood stage 2s this winter. I know I will need to do a turbo, and will more than likely go with a 38r, and I know I will need tunes.
Assuming I have a healthy HPOP, can I get by on it for a little while?
Do I need a full fuel system? or will a regulated return be sufficient? Can I get by with the stock fuel for a little while?
The truck is a 2000.
Jim
You can get by with stock everything, doesn't mean it will like it. Trans mods or built trans, bigger turbo, rr. Stock hpop will drop presure when you get on it, same with fuel pump.
Need to atleast get a regulated return, or an airdog. HPOP should hold up.
HPOP won't keep up with the demand of stage 2's...so a option is a SRP1.1
Clutch won't like it for long, plan on a $1000 package
Reg return and fuel bowl delete.
Head studs and while your there add springs.
Best turbo for stage 2's..modded h2e..much better than a 38r and its rebuildable if ever needed. Plus quite as the 38r is obnoxious.
If we can help we have all.
Cary
Cary
Save up and get a modded h2e like cary said. I'm now looking to build a motor and I don't think the d66 is going to like the new injectors. I wish I would have gone t4 and modded h2e.
1 - 5 of 5 Posts
