1 - 7 of 7 Posts
is it possible to run stage 2's on a stock HPOP? i wanna get DIY 2's but i dont have the money to get both injectors and HPOP at once. i plan on detuning them if at all possible. should i play it safe and buy a HPOP first or can i get away with the stock one for a while
thanks
You can run them on a stock HPOP. It might not get the most potential out of the injectors but it will be fine until you get the cash for a HPOP.
I would get the 17* HPOP
yea your going to want a 17* for sure your 15* puts out a lot less
IF i were you i would save up your money to do both at the same time. That is what i did and i found a 17* hpop on ebay for 150 bucks. you would throw cells all the time with the 15* hpop.
thanks guys, i might just try to save up the cash to get them both
a truck
I would do the HPOP either before or at the same time, you can get tunes that will not throw a CEL but they wont be the powerful tunes, if you really want to crank it up with 2s and a 15* youll most likely be throwing that CEL somewhat often and starving the injectors of some oil
1 - 7 of 7 Posts
