After the 12 teenth time of replacing the drivers side caliper I bit the bullet and picked up an SSBC big caliper kit on black Friday.Finally got around to having everything I needed.Im hoping the calipers,rotors,new master cylinder and complete Crown brake hoses front to back this gets the problem fixed.I can't give much of a performance review because I noticed a coolant leak while installing
.I will say its a noisy setup,which apparently a common issue with rotors of that design.Bolted right up with zero issues,I was slightly concerned about the brake hose,but it worked out well.
