1 - 13 of 13 Posts
Where is the sensor for the speedometer? It's not working and I have some dumby lights on the cluster.. Thanks!
Sent from my Galaxy Nexus using AutoGuide.Com Free App
Administrator
rear axle on top / does ABS also 1 bolt 10 or 13 mm I think
pull and clean it's called a VSS = Vehicle Speed Sensor
I replaced that but it still doesn't work.
That's the abs sensor, not the vss. Any help please
Yeah it's a Turbo Diesel
Idk about these trucks, but on Chevys the vss is in the Trans tail housing
Sent from iPhone
You have an output shaft speed sensor on the top of the tailhouse on the transmission. If it fails though, you should get a code P0720. If you aren't getting any codes, makes me wonder if it isn't a problem with your cluster. May be cheap enough just to swap that out to see. I am not sure which of the two, OSS or the VSS sends the speedometer signal of the top of my head.
**EDIT** looks like the axle sensor they are calling a wheel speed sensor, so I think an assumption that the OSS would be the one to send a signal that will feed the speedometer, but like I say....when it fails, you should be getting a code...
no I was asking because I have never heard of it LOL
what manual ?
Its all good. :beer: The Ford Service Manual.....the one from Ford......a user here posted a link to download a version of it....search for service manual....by far the most beneficial troubleshooting manual you will ever find....by very far....
Administrator
I probably have it downloaded somewhere already LOL I was so disgusted with All Data and Mitchels online ,,
I bought the Ford OEM paper versions
but never miss a free download
1 - 13 of 13 Posts
