1 - 20 of 22 Posts
· Registered
I noticed when going through construction that has the radar billboards my speedometer is 3 MPH faster than reported speed. This is both northbound and southbound, at least 4 different times. Any idea of what it may be before I take her in?
· Registered
Just the way most of them seem to be. Somebody suggested they are being 'robbed' of some warranty.:mad:
· Premium Member
'01 F350 7.3L, 4R100, CC, LB, 4x4
If you have access to a GPS, run the truck with it to see how your speedometer compares. Those construction boards are probably not the most accurate speed sensors.
Reactions: john galt
· Registered
That's what I thought. If it is registering faster than it is going, it's putting more miles on the odometer than actually traveled.
Yes, those particular boards are very accurate.
· Premium Member
Wouldn't hurt to have the dealer look at it. Who knows, maybe they programmed in the wrong tire size. :dunno:
· Registered
They are going to look at it Monday. One of the guys was quick to point out that it is within Fords specs. I told the whipper snapper I have owned many vehicles and this is the first one to register wrong. And for the money I paid it had better be spot on.
· Registered
Simple solution, upgrade to 35's, problem solved.
· Registered
Discussion Starter · #9 ·
Sure, why not.. Now if I can just find where my money tree ran off to. lol!!
· Registered
Discussion Starter · #11 ·
I kind of figured that. Chechecked it against GPS today, and it is 2 mph faster than the GPS.
· Premium Member
Mine runs 1-2mph over as well. My 07 did the same thing and my Explorer is 1mph over at 60mph.
Speedometers are not "certified' to be 100% accurate. I doubt your dealer will do anything. The only vehicles I knew that were certified are police cars.
· Registered
Discussion Starter · #13 ·
I hate to say it, but my GMs were always right on the money. How friggin hard can it be to have a correct speedometer?
· Registered
My last few work trucks where an 09,11,13 and a 14 f250's and they where all off by 2 mph. When doing 75 on the speedo the truck was only doing 73. On my Chevy 2500 work trucks 11 and a 12 and a few loaner trucks I got when mine was in the shop. They where all of by 2 mph the other way. When doing 75 on the speedo the truck was going 77. I've checked this off of gps and used a speed trap sign on the interstate that I pass every day.
Reactions: Turnkey
· Registered
Discussion Starter · #15 ·
When out and about today, it was only off by 1mph according to GPS. So is it breaking itself in or what? I am quite befuddled.
· Registered
The amount it is off will vary by how fast you are going, the slower you are going, the closer it will be to matching; where as the faster you are going, the larger the difference will be.
· Registered
Discussion Starter · #17 ·
Actually, it doesn't matter what speed you are traveling at. It is constantly off by that amount through the whole range of speed which is what befuddles me.
· Registered
Then it is probably how the needle is oriented on the shaft or maybe how which gear tooth it was put in on the speedo assembly.
I would think that if it was some sort of ratio messed up in the mechanism then it would be proportional to the actual speed.
Just thinking out loud as I don't really know.
· Registered
Discussion Starter · #19 ·
One of life's little mysteries.. lol!
· Registered
I threw some 35" tires on mine, it's accurate now!:nod:
Reactions: Turnkey
1 - 20 of 22 Posts
