I am looking into get the boost fooler from SP diesel. I wanted to get a little info if anyone has this same unit on there truck. If so how it works and if they have had any problems with it. thanks.
dieselsite has a good version that works perfect too..
if you get the itp version don't play with it.
put it in, and know exactly what you do to it as far as changing settings.
it can get out of sync and require resetting....ie read the directions first.
other then that it should be easy.
It does not adjust the boost, it fools the MAP sensor.With the itp is there a way to adjust the amount of boost you want or is it set already.
