Hi guys. I came across about 500 gallons of wvo that was claimed to be filtered. I’m wondering how you know your getting good stuff cause it seems like a good deal. What’s the difference between good and bad oil? The food they cook with it?
california deplorable
ANY moisture must be cooked out of it and filtration can not be over emphasized :nod:
most folks heat it and run it through a centrafuge to clear out contaminants :thumb:
if this is a possible on going deal invest in a centrafuge and find a way to cook the oil to remove moisture not real up on the current best method for that as all the wvo within 200 miles has been gobbled up by a subsidized buio diesel plant who winds up charging more for buoo than i can get diesel at the pump for :doh:
that said i run it when i can get it IN THE SUMMER it will gel up faster than good old #2 :D
also be prepared to change out all your fuel filters.
it cleans the entire fuel system better than any off the shelf product out there.
500 gallons...good score :drool:
it has become near impossible to get around here :sad:
Whereabouts are you located? Dunno how that biodiesel plant could snag up all of the grease. I would love to go pick this stuff up but I don’t have the fuge yet. He only wants $100 for it so itd be hard to pass up. And paying 20 cents a gallon sounds awesome. If I did get it, the stuff would end up sitting around until I got the v3 or v4 system and a tank. 4K later I’d have to get the fuge set up. Hmmmm quite a startup
