While replacing the fuel pump on the side of route 95 in Delaware (at night), i cracked the plastic end of the fuel line which plugs into the input of the fuel pump. I cracked half of the full plastic end, not the blue clip.
Ford only sells the complete fuel line from the tank to the pump. It also includes the return line. All and all overkill for what i need.
Does anyone know where i can locate just the plastic portion? I'm happy to splice a new one onto the low pressure side as long as i can find a source.
Final option is hitting a scrap yard. :(
Really, you can just cut the tubing back a bit and use a piece of 3/8 rubber line and clamps.
It's actually an upgrade :wink[3]: When doing the Hutch & Harpoon mod you remove that clip system because although "O-rings" seat well under pressure, they tend to let in air under suction....
Great call! Thanks!
