I was supposed to be gone 2 days ago, but need my truck to do it. Here is a quick run down of work done and current problems afterwards. Like to make the last few days of my trip and be able to get working again. Any help would be greatly appreciated. Thanks.
Well shes back together, and I have problems. I may have overlooked something or another. APR studs installed, factory head gaskets, oil cooler rebuilt, IPR rebuilt, Bulletproof EGR cooler installed, new EGR valve, blue spring kit installed, SCT fitting upgraded. Going to go back through the harness and check connections. Took quite a while to get her fired back up, when it did, idle was REAL rough. Let it run for about fifteen minutes, and ran it around the neighborhood. Smoking like a ***** (black smoke), non responsive to throttle, boost only went up to about 6 lbs. At idle in park, revs to about 3K and then shuts down and drops back to idle with foot still in it. Smoked out the neighborhood and limped it back home. I missed something, any advice where to look?
ETA: Dash gives me a code at odometer to check air intake? But not all the time.
