1 - 11 of 11 Posts
All this started last week. It started smoking when we pulled into a gas station to top off. I filled both tanks and headed back home bc of the running rough and tons of gray smoke. The next day we checked fuel pres. Also checked to see if something had come unplugged even under the valve covers. We tried a computer, I unhooked the bully dog. Nothing fixed. So I told my father lets take it out and run the crap out of it and just see what happens. We left and it smoked so bad you couldn't see behind us. Then after several miles it got better. Then it cleared up. I put maybe 50 miles on it over the next 24 hours. The next day I leave with my boat get 3 miles down the road same problem. So I unhook the boat and carry it down the road. By the way it has plenty of power. Can't get it to go away the time. I think I heard it start to pop back through the exaust, and a sound that souned like a bad valve rattle. Truck lost a lot of power. Went about 2 miles when I made a turn it died. Will not restart. Could the rattle be a turbo? Did I blow it up? Thanks guys
When my turbo went out it made tons of whiteish smoke too, but no power at all and vibrated horribly. It actually shut down too. Do you have oil coming out of the exhaust? Mine was pouring out all over the road.
this sounds like what happened to me when my #5 injector stuck and was over fueling. When you say it won't start, does it crank at all or is it locked up?
Could be a EGR valve stuck aslo.
my two cents
I bet its the injectors,white smoke is no fuel.but to check the turbo just see how much play you have in the fan wheel,it should not hit anything or that much play at all.to check the injectors with out scan tool.take vc off and main wiring harns. make sure everything is clear from heads and plug main back in try to turn it over and have someone watching oil come out the back of injectors see if there all the same? also watch right under the hold down clamps of the injectors see if any oil come out from there.if you still dont see anything wrong check IPR and ICP valves.when was the last time you changed cam sensor.I think you,ll find it, keep kranking
1995 obs
hey man,did you ever find out whats going on with your truck?sh.. ,I wish I could work on your truck for you.I have a 95 with a builted 97 motor.and 90.000 It,s ready.I would do my mods now.17degree pump,160cc injectors,TS FLIP CHIP,3 inch down pipe going to a 4 inch.rebuild turbo and a 1.0 exhaust housing, afe full flow intake,triple disc shift kit there you go 350 to 400 hp cost $2500 to 3000 and that feels real good.it even feels better when you blow away a 5.0 or give him a run for the money.if you need help pm me anytime.later
Yep try your injectors first. Then try a wiggle test on the ICP, EBP and IPR sensors. If you can get the trouble codes please do so.
finding problems
Hey man,did you ever find that bug in your truck?well to put a scan tool on your 95 is going to be if,e most scan tools go from 96 to 07 or at lease my is like that.so, I play it by ear.if you need anything injectors,tubo,etc. I can get them and there awesome.how far did you get into it? do you have any fuel pressure ? hey did you kick the plug off the gas pedal? check it.I did one time and took two days to find it. keep me posted
pm me later
you said it happened just after filling up, what was the fuel pressure , in my opinion it sounds like a truck that running off of gas ionstead of fuel , take a sample and poor some on the ground and see if it lights with a match ,sounds exactly like gas in the tank to me
1 - 11 of 11 Posts
