I'm troubleshooting some running hot under load and coolant loss issues, and wanted a few opinions on some smoke @ startup. Initial white poof followed by blue, then clears up. Never any visible smoke, etc while driving.
Oil analysis has always come back great. No clear contamination in degas. Lost about a pint of coolant pulling 14,000# +- 300miles in last 2 trips. Deleted, studded by PO. Power and overall running is good, tops out 26-28psi boost. I've got a coolant pressure gauge that's not exceptionally accurate but shows I re-build about 2psi after bleeding off from 13psi, unloaded, I haven't done this with 5th wheel on it.
Driving hard under load coolant pressure is 15-18psi on the Auber gauge, which is in bounds of reality. Doesn't "spike" more than 1psi or so. Slowly builds and slowly comes back.
Next step is to pressurize it cold and look really any leaks, but there's no crust or buildup that I've seen so I'm fairly confident coolant is being burned. Will also do a contribution test in the next couple weeks to get a sense of injector health.
I'm leaning to a cracked head as likely culprit, but hoping to get some other opinions before I dig all the way to headgaskets. I run this thing hard, last tandem pull I did I got EOT to 250 then backed off.
Thanks for any feedback or insight.
