1 - 13 of 13 Posts
Ok, I put my 4" SST exhaust on, turbo back and it's fantastic. I spent plenty of time fitting stuff and checking for clearances. However, I have noticed some blk soot around some of the slits where you use a Clamp. It's been on for about 6 months. From turbo to the Xfer case we're good. it's the rear section of the exhaust that has very very minor leaks. I called the tech line when installing and they said to position the clamps over the center of the slits in the pipe joints. thats what I did... Should I move them back? Am I the only guy with this? Exactly how are the clamps supposed to be positioned in relationship to the slits?
I would move the clamp closer the where the end is, that may help crimp it down more and get rid of the leak. I can't help to much though as I put band clamps on mine and they are 20x better than the regualr clamps that came with it. I would look into getting some of the band clamps and you won't have any leaks.
are there any real negatives to having leaks from there on???
just black soot.
band clamps will take care of it for sure, it's not really a big deal unless it just really bothers you.
i have the little leaks at the slits too...i ordered a bunch of band clamps when i ordered my exhaust almost 4 years ago...seems there was a hanger near every joint which prevented me from using the bands..the band clamps are still in my garage...the little leaks are no big deal..
I agree. Like William, I considered the band clamps, but realized that the hangers were the issue. The minor leaks are not a problem.
Discussion Starter · #10 ·
10-4 guys. thats what I figured, but wanted to run it by everyone and see if I was the only one. How did you guys position your Clamps? did you center the U bolt on the slit?
what im planing to do with mine is take it in and just have them weld the joints because mines does it a little too
I am using band clamps and will be welding on new hangers lol. Band clamps do a better job and don't crimp your pipes in case you ever want to take it apart.
1 - 13 of 13 Posts
