1 - 11 of 11 Posts
Hello I have a 2001 F-250 CC with the 7.3, it has a 4 inch lift unknow what band, on it when I bought it. I have order new bushings for the front sway bar{worn}, also I have no steering stabalizer.
I have lots of play in my steeing how can I remidy this?
Check the pitman arm if its loose from the steering box, also ball joints and wheel bearings.
Steering box is what I was afraid of, man that looks expensive and like alot of work, Damn.
stabalizer will help you a lot.
what i charge at my shop is 140 for labor and either 264 or 305 for gear box(32 spline or 36 spline)either way is still a decent price
Thats not a bad price str8ugly
do you have factory steering? If so, I highly suggest a cross-over steering setup... and then get a stabilizer or two.... its easy to know if its the steering box grab your pitman arm and tug it a few times... if it has a ton of play its your steering box, if not then its just the crappy steering that comes from the factory...
if you want a price, let me know.. I have a very reasonably priced setup available
1 - 11 of 11 Posts
