1 - 12 of 12 Posts
I am in the process of putting on a lift kit when i put the wheels back on i noticed the drive shaft by the slip boot was all screwed up and not straight. i took off the universal joint by the front diff in order to get the female and male to line up again in the boot. I guess i over extended and it didnt go back in properly. now it is nice and straight but too long for the lift. What do i do since it will not attach back to the u joint it is mayb e an inch past it. any and all help would be appreciated thanks.
Sounds like you need a custom length driveshaft. How big it the lift??
Oh you need custom for sure bud.. I got mine lengthened and balanced for like $80. Btw you can run without it with no probem
Wait a minute. You put a lift kit on and now your driveshaft is too long? This doesn't make any sense at all.
fixed
Hey thanks everyone for the replies it has been fixed. when i first dropped the axle the driveshaft in the boot had over extended and was stuck because the two didnt line up. i had to take the boot and universal off and i saw that the teeth did not line up so i cleaned it up added new grease and lined it up correctly. thank you for the input. it was an 8" so i think i can still get away with using the stock one. anyone have any trouble with brake lines though? i have new brake lines in the front and they are not even close. new ones came in the kit but are not long enough its a rough country 8" on an 03 f350
You should be Ok with the brake lines. But you will pop the driveshaft back or when going over a big pot hole or something that will extend it. Before I took mine off I would ride around with huge block of wood and a small Jack to put it back in. Get it extended trust me
Discussion Starter · #10 ·
cool thanks i sent u a pm about that roof rack i got the same truck basically except all white but would love a roof rack
Hey is there anyway you could post some photos of your truck? Im looking at getting the Rough country 8" lift too and wouldn't mind seeing it on a few other trucks before i get it for sure. Thanks!!!
-RCR-
1 - 12 of 12 Posts
