I'm getting ready to order a coolant filter and was wondering which one I should get.:dunno: Is there a difference between the two? Is one better than the other? I like the way the Sinister looks. Just looking for opinions.
do you have free shipping?i like the look of the sinister kit.... Sinister Coolant Filtration System / Filter Kit
Does anyone make a kit designed to hold both a oil and a coolant in the same location? It looks like there might be enough room in there, if it was designed right?If you ever do the oil bypass, you will probably need to relocate one or the other, because most want to use the same space in the engine compartment. I already had the oil bypass on, and the dieselsite kit was easy to relocate because the hoses didn't have crimped-on connectors.
