I was under the truck trying to find the source of a massive oil leak and came across a single red wire slightly above the pan on the transmission. Caught my eye because it was just a tiny rusty bolt that was just barely plugged into the transmission. Looks like it at one point had a rubber boot atop it. Any idea what this wire is for??? Maybe a grounding point for something, or a sensor? Clearly looked barely functional...
This red wire doesn’t look OEM like.... That said, is there usually anything mounted on a stock E4OD on the D side, above the pan??
The trans runs and shifts fine. Only throws the blinking OD off light when I really intentionally abuse when testing
