i have a 2004 f-250 that i put the amp research Power Step on but cant get the drives side to work passenger side working fine from both front and rear doors. Any one have this problem need help
I know from what I've read that there are two wires that are the same color and people had a problem getting the right one the first time so it might be the wrong wire or somthing else hope you get it worked out
My steps are bolted in place, no problems here. J/p. couldn't resist. I'd say its a wiring issue myself. you have to see what wire(s) are trigger. you might need to Y 1 wire to 2, and have one to the front door and one to the rear door. just an idea.
