When the temperature starts to get below 40 degrees and the truck sits overnight, it starts up 100% of the time with no problem, It's had this problem since the truck was in Georgia and recently in Tucson the weather has been crazy and getting down to the low 30s like in GA winter. When it first fires up it produces white smoke then it usually clears up after a couple of minutes of idling or if I just rev it hard for a little bit. The smoke usually gets worse the colder it gets. Never have this problem when it's above -45f, or if it's been a couple hours since I last started it. It also makes a noise sort of like a jet engine when you rev it, and idles a bit rough, but again all of it clears after a couple of minutes. Now it has 348k miles on it and I don't know if the injectors have been previously replaced, so I think that might be the problem. But what other things could it be other than injectors and how would I test?
