1 - 7 of 7 Posts
lifetime member
in stalled different custom tune. tranny is flaring and searching for gears. do i need to relearn the tranny? if so, how? do you need to go back to stock when changing between the tunes in the tuner?
lifetime member
Discussion Starter #2
:bump::bump::bump::bump:
lifetime member
:bump::bump::bump::bump::bump:
The tranny does need to learn when you install a new tune. Drive it normal for about 15 miles varying the throttle. No full throttle runs right away. Whos tune did you upload?
lifetime member
some different ones from eric.
Just to add a note here..
When installing custom tunes you should not need to return to stock first. The custom tune will over-write the old program entirely.
When installing a pre-loaded tune, you should always start from a stock tune.
On both situations, you should install the tune and drive it easy with slower gradual tip ins on the pedal to let the trans adapt.
1 - 7 of 7 Posts
