1 - 11 of 11 Posts
Shadetree flying cab (with pics) - need help engine swap, stuck
:eek:hnoes:
Hey guys, I am swapping 6.0 from 05 Harley D 4wd crew, into 05 dually 2wd crew.
Today I was able to lift the cab off in about 3 hours, using roof frame at friends garage, and 2-ton Harbor Freight chain hoist :taze:
If I had all the right tools (20mm crows foot dammit!) it would have been faster. I hooked 15ft straps thru front cab handles, and another one thru rear handles, out thru the doors (windows down) and up to the chain hoist. Front was hooked to upper radiator support with small capacity ratchet strap, to keep it level so it doesnt nose dive. Forgot the pic of straps/hoist, I will post it in the morning :)
Now I have engine on the frame, out from under the cab, its all there in plain view, and I need to remove engine from gear/frame and set it aside.
I cant seem to figure out how to get passenger side engine mount bolts off....they are covered by exhaust manifold....hard to see let alone get to. Whats the proper way to get the engine mounting brackets removed, and pull the transmission off? I tried searching but "6.0 engine removal" mostly finds cab removal or front end removal, nobody seems to cover the actual engine pull off the frame. Also, what else needs to be removed to free engine from frame? How about gear, I found some talk about "inspection plate" opposite side from starter, thru which you get to torque converter bolts, but this 4x4 trans does not have any inspection plates, its just bellhousing all around.....I removed all bolts, except starter bolts, and now dont know what to do next?
Someone please help, in the morning I want to get 6.0 off the frame, lower the Harley cab down, and out of the garage on the trailer, and pull dually in for cab lift and do it all over again :please:
I got the engine mounts off from under the frame. Could not get motor to turn for torque converter nuts to come into view. Decided to pull motor off with transmission attached, and will split transfer case from it. Not sure if there is fluid between transfer case and transmission, looks like they have individual drain plugs?
This may be a dumb question but why are you pulling the motor out of the Harley? Those are some dang good looking trucks.
I agree, they are sharp, installing 50k mi engine from dually into it. It's motor has 155k
Why not just rebuild the current one with studs, etc?
Discussion Starter · #7 ·
Both engines run good, I am building low mileage Harley for daily driver with Fab Tech lift 8" and Banks chip & dual exhaust
Dually is my beater truck, mostly used to haul the boat
I am truly confused with this swap. 155,000 is nothing for the PSD...just getting going
are you at least installing studs and whatnot while you have the motors out of each truck?
I really hope he isn't swapping engines and just leaving them both stock... If so this has to be one of the biggest waste of time projects ever done!
1 - 11 of 11 Posts
