1 - 2 of 2 Posts
Hey guys i got my dads 2000 f350 and i was woundering if there is any way to set the e brake right now it dosent hold the truck. I cant find any adjustment any where so any help would be good
thanks
if you look on the back side of the wheel on the bottom of the axle tube there is a little rubber plug about 1in long 1/4 in tall pop it out and adjust just like you would a disk brake what i did was leave the brake off adjust till it was tight and coulndt turn the wheel (with it jacked up) then backed it off so it wasnt rubbing when i turned the wheel and did the other side then set and released the brake about 5 times and adjusted again if you need more help just let me know (pm me)
1 - 2 of 2 Posts
