1 - 5 of 5 Posts
Hey guys! Any idea on what it would cost to replace the serpentine belt on a 2014 F250? Shop recommendation would be great also. Live in San Antonio, Tx area.
thankk
Cost of the belt, and your time. Look for the idler pulley, buy the correct sized breaker bar. Done. Drink a cold one with the money saved.
Unless you want TruckSourceDiesel to do the work.
Usually the idler pull has a 1/2 drive hole for a breaker bar/ratchet to loosen the pulley. Make sure you're going the right way or you can break the pulley. Depending on mileage, it might be time for a new idler, so consider that too.
His next run will be to go get 400 cases of Coors and bring it back in under 24 hrs lol.
Reactions: Heavy_GD
1 - 5 of 5 Posts
