1 - 9 of 9 Posts
I have a 2012 F350 6.7 automatic dually. I tuned the truck with SCT x4 canned street tune after I did the dpf delete. The truck ran great! A few months later I put an airaid intake and did an egr delete on it. After the egr delete it has not been running right. I returned it to stock and then tried both the canned street tune and tow tune on it. The transmission shifts hard and the truck lacks power. Does anyone have any insight on this? Does this tuner not support an EGR delete?
Did your dash not light up like a Christmas tree when you did the EGR delete? You CANNOT do an EGR delete WITHOUT also deleting the dpf in the exhaust, and you can do NEITHER of these without delete tunes. Canned tunes (out of the box) on the SCT X4 are NOT delete tunes, they are plug & play emissions friendly tunes
If you are not willing or cannot for some reason go all in on the exhaust & extra money for delete tunes, you need to put the EGR back in place and return the truck to the stock tune. Basically either go all the way in, or go all the way back stock. The truck is supposed to run rough because the transmission relearns itself. Will be rough for about 50 miles. If you do go back completely stock, run an update on your X4 to make sure everything is completely 100% up to date, THEN load whichever canned tune you'd like.
I'm willing to go all in and buy the custom tunes. This is all new to me. I will call Innovative tomorrow and figure out what I need to do. Thanks!
I'm confused here, did you do a delete and use a SCT X4 canned non-delete tune? I don't think SCT comes with any type of delete tunes, so if that's the case, how did it run at all with the DPF missing?
lowmpg if I'm understanding correctly, he left the DPF in place. He simply did an EGR delete or block off while only using a canned tune
I did the dpf delete a few months ago and put the SCT X4 tuner on it with canned street tune. Everything ran fine. Then a few days ago I did the egr delete and now I don't have any power but it runs and no lights on the dash.
I purchased the SCT used on Ebay
1 - 9 of 9 Posts
