1 - 7 of 7 Posts
Has anyone noticed after I few minutes on a new tune you seem to lose a little bit of power -even when you go back to the same program you have alot of power then after a few minutes you seem to lose a little or is it just me getting used to the power ?????
you are just getting used to the power. the engine will make the same HP unless something fails.
that sounds ok to me. if you PM DKR, he would kow. he races his a bit.
Discussion Starter · #7 ·
Its not consistant sometimes it pulls so hard then other times i have to push down more on gas to smoke tires maybe its me but in the 1/8th mile stock 61mph stock with exhaust 65 mph economy tune 72 mph and with 70hp tune i turn around 78 mph and those numbers never changed can the convertor heat up for a while then cool down and grab better?
1 - 7 of 7 Posts
