1 - 13 of 13 Posts
Hey guys i just got a livewire ts for my 2007 f-350 6.0. I tuned it to the 50hp tow tune and the truck ran great. I wanted a little firmer shifts so i went to reprogram the tranny with the firm setting and the lock 1-2-3. It went thru all the normal stuff and said the programming was complete and turn the key off. I did and when i turned the key back on to start it i had nothing. The mileage said -------- and the trip said----------. The programmer said general error 11020 and to turn the key off. What is wrong? Any help would be greatly appreciated. Thanks shawn
Its suppose to automatically detect that the key is on, but i had to go through the settings to bypass the auto detect. I didnt have to do that the first time. I checked alot of the fuses and didnt see any burnt ones
did you get this problem resolved? I just installed a ts on my 05 psd today and had the same exact problem, ended up having the pcm reprogrammed before it would crank again. Im about afraid to install this programmer again
same here. tried to go from performance to street and it would not start. gave me error code 110D5. have to wait until Monday morning before I start making phone calls. no after hour customer service for SCT or Sinister
Hello all. I had the same code. Wouldn't allow me to return to stock. SCT have done well addressing my issues in the past, however, I had to send the unit in and it was replaced pretty quickly. Tunes weren't able to be retained and it's been more than a month trying to get them sent to me.
sct fixed me up. half my problem was my laptop it didn't install the drivers to the updater, after I found and installed them everything went smooth after that. sct sent me an update that fixed the issue. now all I gotta do is install stand pipe & dummy plugs, oil cooler, turbo oil feed and drain tubes, blue spring, hpop upgrade, ipr sceen, oil and trannie fluid and filters, cooling system flush, clean the hot side of my turbo and have my egr cooler welded up.
Hey I bought a brand new egt probe for this programmer and never used it their was a time where they were obsolete idn if they are now or not ? PM me if anyone is interested
kickinwelder-ever have any luck getting your programmer right? I am having the same trouble with mine and sct is not being to quick about getting back to me.
2003 F-350 6.0 Powerstroke
Hey guys, I have a problem and need to see if anyone has heard of this before. I have the Livewire TS, and I put the truck in tow/haul tune and locked it in 1-2-3. Started the truck and started driving, and the truck was shifting funny (by funny, I mean bouncing while shifting) after the tow I put it back in street tune and the truck is still bouncing while shifting. If you have any advice I'd love to hear it. Thanks!
1 - 13 of 13 Posts
