SCT Livewire 9600 question
3867 Views 2 Replies 3 Participants Last post by  doubledrop
I just received the SCT Livewire 9600. I see that I can monitor engine coolant temp but can't see that I can monitor engine oil temp....is that correct...if so I'm bummed?
Mine does it says eot check manual to be able to add it. if not it might have came with a update. check for updates.
you can, you need to download the update for the EOT
here is the link, download this file and load it with the update software
info from SCT site
Special note to customers that have a Ford 6.0 Diesel:
There is a new version of the Diesel datalog configuration file that allows logging of engine oil temperature in degrees Fahrenheit
http://www.sctflash.com/software/Diesel.lfu
