Is there anyway to turn off the light on the SCT livewire on the 6.4? without disconnecting it or anything?
You mean the screen lighting or the warning, shift and power lights? If you mean the screen back lighting go into device options and it will alow you to adjust it up or down, if you adjust it all the way down it should be like its off.
yeah iam talking about the screen lighting when i shut the truck off it doesnt shut off i dont want to drain the batteries or anything....so if i turn it all the way down it should go off?
Ok I got you well it depends on what version you have, the newer versions you just hold the esc button for a few seconds and it turns off. On the older ones its the jog wheel that you have to hold down.
Sweet guys thanks ill try both of them thanks
