1 - 14 of 14 Posts
Got my Scangauge II in the mail this afternoon, and hooked it up. Took a long time and some internet troubleshooting in order to get it to connect though.
Started messing around with loading some X-codes. I loaded the code for Oil Temp. Water temp seems to be already preloaded.
I've read several places on the internet that oil and coolant temp differences are a prime indicator of oil and EGR cooler health.
Idling in the driveway with the engine warmed up to operating temp. My Water Temp was 186F and Oil temp was 190F.
Are these good numbers to have??
What are some of the more important gauges to have loaded? I usally only use the truck as a daily driver/cruiser. I rairly tow heavy loads or take if off road yet.
Randy
Read this post: http://www.powerstroke.org/forum/general-6-0l-discussion/259257-write-up-monitoring-6-0l-psd.html
As for the temps, from what I've read the best way to test is at 60-65 mph on a level freeway. Make sure everything is up to operating temperature and any more than a 15 degree differance between oil temp and water temp and you may be looking at doing some work in the near future.
I just bought a ScanguageII and so far have loaded the EOT, FICM voltage, FICM sync, FICM logic power, and ICP. I would start with those. The thread I posted above has a whole section on the ScanguageII.
This may be a dumb question, but I keep seeing reference to "ECT", which I am assuming is "Engine Coolant Temperature". Is it safe to say that the "WT" temperature I read on my Scangauge is the same as "ECT" or is this a different reading?
Thanks,
Randy
Thanks,
Randy
Well, I don't think it's a dumb question. I never asked myself, but I assumed that ECT is Engine coolant temperature from all I've read here. I am using the pre-programmed Scanguage WT to read it
So am I:thumb:
What is the code for ICP:dunno:
Here is a list.
Below I have added to the list of Xgauges Fords specs for most of the gauges.
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE (High idle for these tests is set at 2500 RPMs, and Engine at operating temps)
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Horsepower
TXD: 00
RXF: 400080000000
RXD: 0000
MTH: 000A00240000
NAM: HPR
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Throttle Position 1 (Volts)
TXD: 07E0220917
RXF: 046245090617
RXD: 3010
MTH: 006404000000
NAM: TP1
Note: Voltage of the ETC Throttle Position Sensor number 1
KO=4.0 LI=4.0 HI=3.4 OR=0.7 - 4.2 VOLT Accelerator Pedal Track 1
Throttle Position 2 (Volts)
TXD: 07E0220918
RXF: 046245090618
RXD: 3010
MTH: 0064040000000
NAM: TP2
Note: Voltage of the ETC Throttle Position Sensor number 2
KO=1.4 LI=1.4 HI=1.9 OR=1.4 - 4.1 VOLT Accelerator Pedal Track 2
Throttle Position Desired (Degrees)
TXD: 07E022091A
RXF: 04624509061A
RXD: 3010
MTH: 0064020000000
NAM: TPD
Note: ETC Commanded Throttle Angle, in degrees.
Throttle Position Actual (Degrees)
TXD: 07E022093C
RXF: 04624509063C
RXD: 3010
MTH: 006402000000
NAM: TPA
Note: The measured throttle angle from the throttle sensor inputs.
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Throttle Position Control Signal
TXD: 07E022096C
RXF: 04620509066C
RXD: 3010
MTH: 00647FFF0000
NAM: ETP
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Desired (%)
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Fuel Level
TXD: 007E02216C1
RXF: 0462451606C1
RXD: 3010
MTH: 000101480000
NAM: FL
Volume Fuel Desired
TXD: 07E0221411
RXF: 046245140611
RXD: 3010
MTH: 006400100000
NAM: VFD
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Engine Run Time (Minutes)
TXD: 07DF011F
RXF: 0441051F
RXD: 2810
MTH: 0001003C0000
NAM: ERT
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Manifold Absolute Pressure (PSI) (BOOST)
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
12.7 FF81
12.8 FF80
12.9 FF7F
13.0 FF7E
13.1 FF7D
13.2 FF7C
13.3 FF7B
13.4 FF7A
13.5 FF79
13.6 FF78
13.7 FF77
13.8 FF76
13.9 FF75
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
Fuel Injector Pulse Width (Microseconds)
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
Gear (Transmission Gear)
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100020000
NAM: GER
Self explained
Vehicle Speed Sensor (MPH)
TXD: 07E02211C1
RXF: 0462051106C1
RXD: 3010
MTH: 000102000000
NAM: VSS
Self explained
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Net Torque into Torque Converter (Ft-Lbs)
TXD: 07E02209CB
RXF: 0462050906CB
RXD: 3010
MTH: 000100010000
NAM: TRQ
__________________
Also on the Scangauge site there is an alternate engine coolant temp that can be entered in, its supposed to be a little more accurate than the pre-loaded one.
I apologize if its listed above and I didn't see it.
I found a mount for mine off ebay as well. I dont like the idea of tap or something i like the finished look. Just another $50.00 dollars!
Does this allow you to set the position of the valve? in other words would it turn of the EGR valve like the SCT does?
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
Nope.
You can't command anything with the SGII. Just read PIDs.
1 - 14 of 14 Posts
