Wrapped up the install of the S&S CP4 Disaster Prevention kit about a week ago on my 2020 6.7L, checked for leaks and can't see anything from any of the connections. I'm getting strong fuel smells now, and even comes in through the vent to the cab. I thought it may be residual diesel from the install that spill down the side of the motor, but I hosed it all with brake cleaner, but the smell gets stronger when cycling the pump. I've checked for leaks with the ignition on and pump priming, as well as with the truck running. Before I tear down the upper and lower intakes again to do a closer inspection of everything, does anyone else have this kit and get a fuel smell? Whether its just from the new filter letting fumes get past, or something else to look for?
