1 - 20 of 29 Posts
So I just installed all 8 injectors now the truck wont start and is throwing low circuit codes for 6 injectors? Comes up to oil pressure but doesnt even try to start? Also threw a Low ICP code:(
The low ICP code is from having the oil rails off. It's going to take a minute or 2 of cranking to get ICP built up enough to fire.
Injector circuit codes can be caused by a failing ficm. why were you changing the injectors to begin with? Make sure the FICM harness plugs are fully seated
The FICM is reading 48v so i figured thats good? The injectors were changed because it felt like i had a bad spool valve on one, Would feel like driving on a gravel road
ICP reads 0.4 when trying to start and doesnt move?
Oil pressure goes up after cranking a second and holds untill i stop cranking then a second later drops off as well
ICP should go up to around .7 or .8 before it will fire
did anything happen going back together that was questionable? standpipes line up okay? the 04s can be a pain in the butt sometimes
I did put the udpated stand pipes in? Seemed to go together ok oiled them and put them in torqued down to 60lbs? I put updated dummy plugs in as weel
I put the longer piece in first,had to tap top piece in to get it to start threading. That was on both sides
yeah that sounds normal. the longer piece sits down in the branch tube and needs some pushing to get it started
i dont know what to do
Discussion Starter #11
I got it to fire!!! Just now it sounds like its running on 7 cylinders???
Discussion Starter #12 (Edited)
So the ficm plug was a bit loose. Now it runs but it smokes and sounds like it has a bad miss which is similar to what it was doing before other than the smoking?
I thought I was capable of doing this repair,I guess not. I took my time and torqued everything to spec
Discussion Starter #13
If I let the truck sit a minute it takes forever to start again...Then it smokes and feels like its running on 7 cylinders
Discussion Starter #14
The Whole story
Ok about a month ago my truck started to get a little bit of a miss and then it got worse as in would feel like traveling on a gravel road every once in a while.
So I ordered all 8 new 155/stock from warren diesel and put them in yesterday and today also decided to do updated stand pipes and dummy plugs while I was doing it.
Got it all back together and the truck takes forever to fire,ICP stays at 0.3-0.4 for a while and takes a good 10-15 seconds before it will start. The Fuel PSI builds up to 64 psi while starting but has little to none with just the key on:dunno:
Then it will start but when running it runs like its on 7 cylinders and smokes,Never smoked before but did have a miss. Also is now not throwing any codes.
Just looking for any suggestions? I'm at a loss
The new stand pipes not building pressure to start? I cant believe so many have things have gone wrong
I know, it can be difficult sometimes to troubleshoot these things on your own. I replied to your PM
Discussion Starter #16
Discussion Starter #17
Ok just to update this it looks like received a faulty injector so they are sending one over night and hopefully that fixes the issue. I checked all the wiring today and everything looks good
Discussion Starter #18
Got the new Injector installed tonight and all is well again. Thanks to all for the Help especially Sinner 6.0l for the PM help
Discussion Starter #20
1 - 20 of 29 Posts
