1 - 16 of 16 Posts
Hello all. It's been quite some time since I've visited. I am wanting to upgrade the suspension on my truck (1997 f350) and am weighing everything about installing a RSK or 08+ axles.
Can anyone share their experience with either or both?
Which one would ride better? I like the little lift of the RSK, I like the oem of the 08+, I like the bit bigger tires (17") with 08+, I like keeping 16" tires because I just purchased new coopers (haha).
It's very hard to find 08+ axles especially if you're not willing to purchase the entire wrecked truck - from what I've ran into, of course. I would like 3.73 (my truck has 4.10)and 4x4 (I'm pretty sure that matters, since my truck is already 4x4??).
I thought I would just ask on here and maybe start up a discussion comparing them. I've read almost every thread on here regarding both as well but never seen anyone compare something like this.
Thanks for reading, have a good day.
If you have the ability to do it, go with the 08 setup front and rear. You will gain disks in the rear and larger breaks in the front, better turning, more room for turning with large tires, better ride and stronger axles. Downfalls are possible death wobble and unit bearings, both of which can be fixed, larger rims 18"+ IIRC and possibly a higher cost/more difficult install. Also, your current D60 should sell for around $1000 which will cover most if not all of the cost of the new axles.
When I was doing my 95 I had originally planned on 05 axles but due to rushing into the project and my comfort level with the install I went with a leaf sprung D60 axle. You should contact Cary, he can steer you in the right direction for whichever axle you use.
Delivers Pizzas For Fun!
i did the 05+ axle swap. I LOVE IT!!!!!... look on CL for someone parting a truck and ask for a price on a rolling chassis. go to JY's and ask. i see them quite often but it depends on how much you wnat to spend and how far you wana drive. i picked up my roller minus wheels as i already had some for 2000... just after i bought it i saw a roller minus wheels for 1800... go figure. BUT, i drove from MD to GA to pick it up which was 12 hrs but i made a good time out of it. i would suggest getting a roller as they are easier to deal with and it allows you to take measurements and stuff. also gives you an idea on stock angles of track bars, pinion angles....ext
only thing i would change if i did it again, i would have made my own track bar mount(which i still may do sometime), get the SD drive shafts of the same style(lenght) truck, and maby get the SD powersteering box and pitman as the box has softer valving. nothing wrong with the OBS box. just saying if i do it again.
also if you keep you OBS box make sure when you get your pitman reamed out, use a F350 arm and not the f250 arm. it make the ateering angles better!! or get a E99 pitman as it is slightly longer and even straighter and will fit over the OBS box splines.
and cant thank Cary enought for helping me along with this project!!
Ol blue, I've read your write up about 100 times. I feel I could do this swap in my sleep just from that!
So in reality, a RSK would run me around 1200-1300 after all said and done and 05+ axles a little over 2k for a "new" truck? I like that idea...
Also, I'm assuming 05 is the same as 08+? I was under the impression that 08+ had some even better goodies.
You do not use a RS kit with '05 up axles..you use a 4 link kit along with some factory parts.
Costs will be more unless you find a killer deal on axles etc.,
'08 axles have larger brakes and rear has a wider track. They also have a larger front sway bar that keep the front flat when cornering..'05 is much smaller and you do get body roll and a softer ride.
We been doing these for 4 years..
Thanks Cary.
I was more so comparing the two prices, not adding them together :D
Can you send me a PM with a price of what your place would charge for a complete swap including everything needed?
Thanks.
Sorry my bad...
Sure, I''ll need to know what you have, what tires and rims you want etc....or you can buy mine already done with leather interior and 450HP!
You do know I'm in NV....but I've had trucks shiped here from Il and Tn, etc.....
cary... have you ever done a swap on an OBS and used the 5 spoke KR 20s? i picked up a set, just wondering as i still need to buy tires and it will be a while
Discussion Starter #12
That's an interesting offer, Cary!! Haha, I'll keep it in mind!!
The truck is on the road mostly so location isn't that important.
What are the options with wheels? I'm not knowledgable with newer styles and I would like to stay with an oem style. I'd like 17", 18" max. Anything else is too big for our OBS's, IMO. The sig pic above me has some NIICCCEE wheels but I'm steering away from anything chrome or silver.
Thanks all!
Thoes are the 18" lariat wheels...cary has the 08 20s on his, the 8 spoke ones. Basically any wheel on an 05+ truck will work.
I do like them 8 spokes too! I see u like white trucks cary
1 - 16 of 16 Posts
