Just want tho post this for all the Northern "Salt" Region PSD Folks:
If you have RUST on your oil pan, take care of it immediately!
Mine is in REALLY bad shape, and although it is not leaking YET, it is beyond repair, and I will have to "Band-aid" it until it does leak.
It is rusted all the way up the pan, under the cross-member, and in places where I could not tell until I cleaned it up and started scraping the paint off. It's horrible, I found one spot where it is clearly indented approx 3/32 of an inch.
I knew it had rust, but it was so covered in grime that I had no idea how bad. When I cleaned it I noticed it was worse than I thought, but after scraping the paint off and seeing how much rust pitting there actually is... I hope and pray I can go another 2 years before I have to pull it and replace it.
FTR, when it does come to that point, I plan to buy the equipment to do it myself... and do the exhaust manifolds, bellowed up-pipes, and new studs on top and bottom. That is the plan, anyway. :tard:
FIX IT BEFORE YOU CAN'T, FOLKS!!!!!!!!!!!
